Merlin on GS-AX3000?
dwp
I just got a new GS-AX3000 and I find that it does not have a tcpdump binary installed in the stock firmware. I really need that ability and I see that there is a package for it in Merlin. But it appears that Merlin does not support this router. I see that it does support the RT-AX58U/RT-AX3000 and read here that the hardware of my new router is the same. I don't know if I am taking this too literally or if this is correct info. But if so, can I run Merlin for the RT-AX58U on this box? Thanks!
And the answer to the inevitable question of why isn't it on the list can be found in this post:
No there isn't a package in Merlin for tcpdump. There is a tcpdump package in Entware, and Entware can be installed on Merlin-supported routers.
You might be able to install Entware on stock firmware but I don't know for sure.
Thanks for your replies. I figured this would be the case.
And thanks for the pointer to Entware and I will look into seeing if I can get it only new router. Cheers
Just managed, with some tweaking of the linked instructions above, to install Entware's tcpdump on the stock Asus firmware. Thanks so much!
