Merlin Scripts not present in JFFS
Timmons
Hello,
I'm trying to install a custom script (the ipset directions https://github.com/RMerl/asuswrt-merlin/wiki/Using-ipset)
I formatted the jffs and can move files there but the user scripts that come with merlin (i assume) are not there
https://github.com/RMerl/asuswrt-merlin/wiki/User-scripts
It mentions doing this
Finally call this at the end of your existing /jffs/scripts/services-start or /jffs/scripts/post-mount:
# Load ipset filter rules
sh /jffs/scripts/iblocklist-loader.sh
But services-start and post-mount are not present at all. am i missing a step?
Pretty much everything is gone from jffs the folders are there but that's about it.
You have to create them. The firmware has hooks to call the supported user scripts at the right time, if they exist.
Some of the scripts floating around here handle the creation of the user script; skynet for example.
All i want to do for now is run ipset to handle the iblocklists. Is skynet the most popular/standardized one?
Yes. Add Diversion to. It will block ads and other bad hosts.
