Merlin WebUI http server stops responding?
Rici
On my RT-AC86U running 384.18 is does after a few days (scmerlin helps to get it manually restarted).
Is this a known error?
The issue seems to pop up in the forum every week or so, it seems to affect users randomly ,i came across it months ago , to mitigate the issue i run a cron job every 6 hours in order to restart the server from (services-start) never had any issues since then.
cru a restart-webgui-at-6-hour "0 */6 * * * service restart_httpd"
I also occasionally have this GUI problem, so I decided to add a cru line to do the restart. It has been working great, but after about 1 day, when I look at the logs, I see this. Why is this happening? Is this related to the https restart?
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: httpds: page allocation failure: order:5, mode:0x2040d0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: CPU: 1 PID: 14973 Comm: httpds Tainted: P O 4.1.27 #2
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: Call trace:
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc0000876d8>] dump_backtrace+0x0/0x150
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc00008783c>] show_stack+0x14/0x20
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc000508964>] dump_stack+0x90/0xb0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc000101f28>] warn_alloc_failed+0xd8/0x120
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc0001045ec>] __alloc_pages_nodemask+0x404/0x6a0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc000138de0>] cache_alloc_refill+0x350/0x610
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc000139330>] __kmalloc+0xb8/0x100
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffbffc00025c>] wlcsm_nl_rcv_skb+0x25c/0x3c0 [wlcsm]
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc000401da0>] netlink_unicast+0x150/0x228
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc000402268>] netlink_sendmsg+0x2f0/0x350
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc0003a1fe0>] sock_sendmsg+0x18/0x58
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc0003a2b5c>] ___sys_sendmsg+0x26c/0x280
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc0003a5420>] __sys_sendmsg+0x40/0x80
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: [<ffffffc0003e1448>] compat_SyS_sendmsg+0x10/0x18
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: Mem-Info:
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: active_anon:1937 inactive_anon:2397 isolated_anon:0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: active_file:3133 inactive_file:3078 isolated_file:0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: unevictable:0 dirty:22 writeback:0 unstable:0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: slab_reclaimable:996 slab_unreclaimable:65868
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: mapped:2415 shmem:233 pagetables:572 bounce:0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: free:8963 free_pcp:21 free_cma:0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: DMA free:35760kB min:20480kB low:25600kB high:30720kB active_anon:7732kB inactive_anon:9588kB active_file:12536kB inactive_file:12308kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:495616kB managed:440420kB mlocked:0kB dirty:88kB writeback:0kB mapped:9652kB shmem:932kB slab_reclaimable:3984kB slab_unreclaimable:263520kB kernel_stack:2720kB pagetables:2252kB unstable:0kB bounce:0kB free_pcp:108kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: lowmem_reserve[]: 0 0 0
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: DMA: 2299*4kB (UEM) 1741*8kB (UEM) 647*16kB (UEM) 14*32kB (UM) 1*64kB (R) 1*128kB (R) 0*256kB 0*512kB 1*1024kB (R) 0*2048kB 0*4096kB = 35140kB
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: 8418 total pagecache pages
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: 1974 pages in swap cache
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: Swap cache stats: add 525031, delete 523057, find 80069008/80247147
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: Free swap = 2059000kB
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: Total swap = 2097148kB
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: 123904 pages RAM
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: 0 pages HighMem/MovableOnly
Aug 20 08:04:49 RT-AC86U-1BD0 kernel: 13799 pages reserved
Sounds memory related (page allocation failure). Since you have a swap configured, make sure that swap is working properly.
A reboot seems to have fixed it for now. I'll watch it to see if the error reappears.
I put this in and then rebooted router. And it didn't stick. Is there a way to add this so it survives a reboot?
on "/jffs/scripts/services-start" file.
After 3 weeks of rock-solid performance of my Asus router running 384.18 I now can report back: @faria your hint above (with the cron job for a nightly restart of http daemon) was AWESOME !
Thanks a lot!
No issues since I implemented that.
3 weeks? Seems less than two, but anyway... :)
I put the added script, but still experiencing GUI issue. Occasionally, when I open GUI, the GUI opens, but the Menu items on left column don't show up. If I close the web tab, then reopen the GUI, I am already logged in and the menu items are on the left. Perhaps I need to run the script more frequently?
