Merlin WRT IPSec VPN Server - IKEv2 only
Itzap
Hello community,
im searching in the web since hours and i couldn't find the right explanation or guide for it.
I want to use my IPSec VPN Server on my RT-AC5300 router with latest merlin wrt firmware on it.
As i am out of it security since 15 years i was not aware that IKEv1 is described now everywhere "as unsecure" and everywhere just IKEv2 is recommended.
So in my IPSec configuration (GUI) i can't disable IKEv1, so the workaround would be just to allow IKEv2 connections / users. But the dropdown in the GUI just allows "IKEv1" or "IKEv1&IKEv2" users.
On asus faq they recommend to add users with just IKEv2 supported version.
So i am a bit confused why this isn't possible in the lastest merlinWRT, i just want to allow IKEv2 connections and fully disable IKEv1 support.
Thank you very much!
[EDIT: I see the faq is for another firmware / router models, that should be the answer. Anyway does anybody has an idea to implement the issue above in my model with a workaround or something?]
Just a short feedback:
I've read articles about the "Bleichenbacher" method and others how they break into IKEv1 and even IKEv2 handshake, so all the clients are using IKEv2 even if the server still accepts IKEv1 requests from what i know now one of my clients must at least try a IKEv1 connection to open the possibility for a security vulnerability.
Thanks anway, this thread can be closed.
Have a great 2025 everyone!
Mhm as a "workaround" i've removed the whole IKEv1 block fom ipsec.conf (+increased dpddelay)
#Host-to-NET[prof#0]
conn Host-to-Netv1
keyexchange=ikev1
Then copying it over +live reload via /jffs/scripts:
cp /jffs/configs/ipsec.conf /etc/
ipsec reload
ipsec statusall then shows only listening for ikev2
So far so good, ikev2 clients still connect fine - but i'm a bloody newb when it comes to ipsec configuration 😝
Maybe @merlin devs:
Is there any particular reason there is no v2 only option during user creation respectively no advanced configuration possibilty (like v2 DPD times) at all?
In OpenVPN we got a Custom Configuration part at least.
Cheers,
N0rd
Maybe @merlin devs:
The IPSEC implementation is 100% from Asus. I don't make any change to it because I'm not familiar with IPSEC.
Ah okay same boat then 😌 thx for super quick clarification!
PS: Initial idea + some more reasonable cipher settings are originally from @CB7
Cheers!
