Hi guys,
Moved to a new house and trying out the best fit for Mesh Network. I live in Canada and have Bell Fiber which is tagged Vlan. Bell provides it's own Home Hub 3000 router which I don't like.
1) I started with Google Wifi, great to setup, two were good enough for the whole house. Lacked Vlan tagging feature. Configured it as PPPoE and could not get more than 600Mbps download. Even bypassed the HH3000 through a manged switch (Edge Router SFP) and still no luck. If I had GW configured in Advanced DMZ through HH3000 (no PPPoE), I would get full 950+Mbps on wired connection. I figured it's GW limitations. GW acknowledges they have issues with PPPoE. Ended up returning it. Please note, GW was connected to ethernet backual.
2) Now I'm using AmpliFi HD. I'm using two routers Meshed via ethernet backhaul. So far it's been working fine. Vlan tagging feature is available so that's a great plus. PPPoE connected, however download speeds on wired hovers around 550 to 600 mark. Support is aware of this issue and plans to release an update. It has been an ongoing issue for a while now. Again the two routers are connected through ethernet backhaul.
3) Next and finally I'm thinking of giving onHub try. I really liked the simplicity of Google Wifi and onHub does the same thing but cheaper. I paid $400CAD for Amplifi HD but I can likely get onHub two routers for $200CAD.
Do you think it's worth checking it out? It is google platform but my worry is if eventually they would stop supporting it. When I compare OnHub specs to Google Wifi, it seems like it's more powerful. 12 antennas versus less in GW and only 6 in Amplifi HD?
Seems like it would be much stronger for half the price of Amplifi.
