dssguy1
Hello SNB community. I've been a long time lurker absorbing network advice for over 10 years from SNB and every time I get close to updating my network, I come here to get the latest and greatest advice. I've been a long time user of ASUS hardware and do want to stay with ASUS if I can, since I am so familiar with the interface.
Could I please ask for some tried and true suggestions for my complete network overhaul?
Facts:
- 2 story house with basement. Built in 1993, typical wood and drywall construction. About 4000ft^2 above ground.
- I have 1gbE up and down with fiber internet.
- I typically believe I want a router and 2 satellites. Router on main floor in office towards one side of the house and each satellite on the other side of the house, one in basement and one on the second floor.
- Both my sats will be hardwired straight to the router with Cat 6 cable
- I have an 8 port 10GBE switch in my basement that I connect to all my higher capability devices (computers and NAS) and then connect directly to the main router (preferably to a 10gbE port on router)
- Basically everything with a wired port, is wired, I have run ethernet everywhere in the house. No streaming devices are using WIFI except for Echos. All computers, laptops, TVs, shield devices, etc, wired.
- I have about 45 IOT devices and would like them on a separate network. Mostly Kasa smart switches, 7 echos, a couple light switches, ecobee thermostats, Nest Fire detectors, fridge, a smart things network.
- Total I have around 60 devices on the whole network.
- I have a few devices that should work with WIFI 7, but really, it isn't that big of a deal, would just prefer not to have to update everything in a couple years if I could just get the capability for WIFI 7 now and possibly just turn it off until it is more stable. We have new Apple devices that can use wifi 7 but I struggle to think of why I would need that speed on an ipad or iphone.
- I do like to use wireless PCVR with my Quest 3 (Wifi 6E is all it can handle)
- I want stability and performance if it exists!
- Money isn't a big concern, I would rather pay more and not have to mess with it for 5 years, versus needing to upgrade in 2.
I did take the plunge and upgrade from a GT-AX11000 ROG and 2 XT8 sats. I purchased the 3 pack BQ16. So far it has been ok, no major issues but it seems a little buggy sometimes I check and 40 wireless devices are connecting to my router and 0 to one of the sats and 4 to the other. If I reboot, it will more evenly distribute. Meta Quest 3 disconnects more often then my previous setup. I basically turned off MLO and Wifi 7 because I knew I wasn't really using those features. AT the end of the day, it was a $1250 (had a couple discounts) investment and I read that very few have this setup, Merlin doesn't support it and a lot say that they consider it 1st gen hardware or buggy.
What are the GURUs suggesting for my particular setup, if robust wireless, Merlin support and trying to future proof my setup were priorities? I would also like the ability to use my 10gbE switch with a proper connection to the router if possible.
I did do a fair amount of research but I was finding differences in use cases across a lot of the recommendations and some dated responses that I wasn't sure if they still applied in 2025.
Any help would be much appreciated.
Facts:
