Method to map the connected USB storage
p71
I am struggling with this issue. My pen drive and external hard drive are connected to the AC66U USB ports. How can I map these storage in Windows 7?
I can access them through the Cloud service and ftp, but it would be nice to access them as a remote disk.
Thanks!
Thanks!
Use the AiDisk wizard on the USB page. The Samba Windows File Sharing option is what handles network sharing.
I enabled the USB stick share without account but in Windows Network neighborhood I can see only the router itself but not the connected stick. How can I mount it?
On the USB page, go to the Servers section, then to the Windows File Sharing page. You will find the options there to enable/disable sharing, manage shared folders, etc...
Also make sure to go to the last tab of that section, and set the Workgroup to match your network's.
