Minor bugs
StR
Reporting based on 380.69_2 (on RT-N66R), but I've observed this in the previous versions as well:
1. Page /Main_TrafficMonitor_realtime.asp
The link to "Traffic Monitor FAQ" is broken.
2. I don't know if this is intentional or accidental: When you are installing a new version of the firmware, the message says that it takes at least 3 minutes to complete. The built-in update status counter takes more than 4 minutes until that same windows says 100%/completed.
3. (update) Links from /Advanced_VPN_OpenVPN.asp page are also broken:
  1. Windows
  2. Mac OS
  3. iPhone/iPad
  4. Android
These might not be relevant for the legacy branch, since only major upgrades will be issued, but I am guessing, it might be the same way in the new branches.
PS. Thanks for your continued support of the legacy routers. RT-N66R is still a workhorse perfectly suitable for many non-demanding applications.
Asus modified their support site, it broke all the FAQ links for older firmware.
This is already fixed in 384.3. The 380 series is no longer actively developed.
