Hi all,
I've come across several similar threads but nothing helped so here it goes:
Somewhere around when I upgraded to 386.5_2 my addons page from the webui went missing, multiple reboots (from ssh, web and from the power grid) did not solve it. I'm running several addons (see below) and if I manually go to the user1-5.asp in browser address bar, page for that addon works, here is the mapping:
user1.asp - Diversion
user2.asp - spdMerlin
user3.asp - scMerlin
user4.asp - uiDivStats
user5.asp - Skynet
grep redirect /tmp/menuTree.js - yields no result
grep user /tmp/menuTree.js
{url: "user1.asp", tabName: "Diversion"},
if(userRSSI_support){
I've enabled the NTP watchdog script in scMerlin but this only changed Diversion mapping from user2 to user1
scMerling says I have only Diversion mapped as WebUI addon, but the is still no addons tab on the menu on the left
Going into amtm config for any addon I get the following (regardless of the addon):
WebUI for scMerlin is available at:
WebUI page not found
Start up log say the following:
Jul 26 18:29:25 XXXXX scMerlin: Mounting WebUI tabs for scMerlin
Jul 26 18:29:28 XXXXX scMerlin: Mounted scMerlin WebUI page as
Tried manually deleting menuTree.js and reboot - no change
Today I've upgraded to 386.7_2 - no change
Any ideas ?
user5.asp - Skynet
Any ideas ?
