MLO Network Name
hodgeadam
Question - when you all create MLO networks are you naming it differently than the other wireless networks? I have a meshed BE98/96U network. I turned on smartconnect all radios. I set the 2.4 to 20mhz only. Everything else is default. That ssid is the same as my MLO ssid. Should I rename to force the iPhone on to that? iPhone 16 pro.
