Monitor local machine that makes many connections blocked by Skynet
poudenes
Hi All,
How can I monitor a machine that try connecting a destination and that IP is blocked by Skynet.
I want to see what hostname is requesting... Because my NAS is trying to connect. But have almost 2341 blockings of skynet.
Can someone assist me with this?
If you look in the router UI under the Firewall (Left Hand Menu), you'll see a SkyNet tab, which includes a summary of the most blocked sites and machines. If that's not enough then you'll have to download the logs and sort them using a spreadsheet.
*See how you get on with that for now - I'm sure we can post more info if you need it*
It's important not to get too paranoid for no good reason!
**There is a utility available on Github that allows LibreOffice Calc to look up DNS and return the results! ***That is not a recommendation, you'd still need to do your own due diligence!
I did a reset of the log to see a clear log. Before had a very aggressive blocklist. Now back to my own.
The info was because of the other blocklist. Bassicly googleapi.com related domains.
Everything is ok now :) thanks for the information
