gdgross
Hi all, I'm (slowly) educating myself about how to set up a vpn server on my home network. I've asked a bunch of newb questions here and here.
I now have a TP link ER605 wired router in my network, and have my wifi routers set up in bridge mode (which means they are access points, and don't assign IP addresses, I understand) so that the router can be the router. This ER605 router has the ability to set up a VPN server itself, and I'd like to do this to enable remote access to my network, internet, or even log on to my mac mini remotely.
On the VPN client side, I'd like to use one of the options built into windows 10, which appear to be these:
With that in mind, I've started setting up an L2TP VPN server on the ER605, but I have some questions:
Sorry if these are noob questions! I'm a networking luddite, but I'm learning.
Thanks!
Geoff
- I'm guessing the server IP an INTERNAL IP address that I'm assigning to the server on my LAN only?
- If so, how would I access this remotely? I didn't see anywhere in the L2TP setup a place where I needed to add a URL or something to access the VPN server, or a way to identify it remotely.
- What's the remote subnet, and what should I be putting in this spot?
Thanks!
Geoff
