Motorola AC2600 = Netgear R7800 ?
consorts
"motorola" name was licenced to zoom
https://motorolanetwork.com/mr2600.html
these specs and even stock firmware
sounds like a netgear r7800 would.
the user manual pdf is not very detailed.
it seems to be marketed as both mr2600 and/or ac2600
which only makes finding information on it more confusing.
but i can't find anything about what
cpu ram radio chips AC2600 is using.
does anyone have better AC2600 information?
it often sells new + 2yr warr for only $100,
so worth looking into if it's a near R7800 ;)
i don't think it's like the discontinued Trendnet TEW-827DRU
based on where the USB3 ports are (far from 2.4ghz antenna);
http://www.trendnet.com/support/supportdetail.asp?prod=100_TEW-827DRU
