I need to replace a dying N66U. I have a new in the box never used AC86U, manufactured in 2018, with hardware version R1.5 and firmware 3.0.4.384, that I can use. But I'm also wondering about going right to an AX68U or an AX86U instead. I just can't decide which of those two would serve my needs best if I go that route.
The AX86 would be overkill. I wouldn't use a lot of the capabilities, but I would welcome the stronger signal strength. And I love the support in these SNB ASUS forums and I notice a significant difference in the number of posts for the AX68 (fewer) vs. the AX86 (more) . . .
Or should I just start off with the AC86U I already have and let 6G\6E mature before I dive into AX routers . . .
I don't game, mainly just browse, stream, email, etc., with two phones, three laptops, and a Roku.
I'm in a 1200 sq. ft. two bedroom apartment, drywall and studs structure. The internet comes in on the opposite side of the apartment from the bedrooms. In-between the router and the bedrooms, where WiFi is weakest, are the furnace room and the master bathroom.
Thoughts? What would you do?
