moving settings CFG from from n66u to ac87u
mrbg07546
Im upgrading my n66u to ac87u
I have key settings such as
router local ip, VPN, port forwarding, servers/ftp
is it possible to just load the n66u config on the ac87u?
Differente devices, different config file. You should config it manually.
You will have to do it manually, one setting at a time. You can generate a text-based list of your settings through SSH:
nvram show | sort
Then manually set the desired settings on the new router:
nvram set vts_rulelist="your_port_forward_list"
... other settings ...
nvram commit
