kohht
Hi, I'm having some issues turning off MPPE.
Currently here is my setup.
VPN server: Asus AC68U
VPN type: PPTP
Setup: Authentication chap version 2
MPPE: Ticked 128 and no encryption
VPN client: E4200 V1 running on Tomato
WAN type: PPTP
Gateway: To my Asus
Im trying to setup my E4200 v1 PPTP without using any encryption. I tried leaving option text field blank but it seem like the default using 128.
What is the option to disable 128 and run with no encryption.
I try no-mppe but my Asus log spamming too much with "no such configuration".
With 128 running, it will slow down the network too much. Since I got lots of user at E4200 site.
I tried running with nomppe but spamming my log isn't what I want.
Can anyone share what to input the option. Thanks.
Rion
VPN type: PPTP
WAN type: PPTP
Gateway: To my Asus
Jan 31 20:51:45 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:51:48 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:51:51 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:51:54 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:51:57 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:00 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:03 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:06 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:09 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:12 pptp[17658]: CCP: timeout sending Config-Requests
Jan 31 20:52:14 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:17 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:20 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:23 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:26 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:29 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:32 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Jan 31 20:52:35 pptp[17658]: Received bad configure-rej: 12 06 01 00 00 40
Rion
