Msconfig
jaygreg
My Dell XPS435MT had to have a motherboard replaced within three months of initial purchase. The tech who came to my house failed to make me whole again after the reinstall; he left a "Dell Remote Access Setup" window pop-up; it appears each time I boot.
Dell Online Tech Support stopped the window last night as a courtesy (after some brief exchange) by having me disengage all checked items in MSCONFIG then restart. I was told "Goodbye" and sent on my way.
Well... the pesky Remote Access window is gone at boot up... but so is everything else except Kaspersky Antivirus (which conflicts with Windows Defender which is also a line in MSCONFIG.... but I don't know if it was check or not initially). I'm sure I'll find no reception at that Online service again which I'm sure is third party rather than a Dell department. I could sure use some help as to what to put check marks to in the list below. The only one checked before I decided to tamper then stopped myself was the Kaspersky. Something tells me I need better advice than I started to give myself. Should I select them all again (less whichever one stops the pesky RA window) or are do I need to ne more selective and if so... which ones do I turn on?
1) Kaspersky Anti-Virus Kaspersky Labs
2) Adobe Reader and Acrobat Manager Adobe Systems
3) Adobe Acrobat "
4) ArcSoft Connect ArcSoft Inc
5) EPSON Status Monitor 3 SEIKO EPSON
6) EEventManager Application "
7) Microsoft Windows Operating System Microsoft Corp (and this was turned OFF ????)
8) EPSON PC-Fax Software SEIKO EPSON
9) ISUSPM Startup Unknown (Was this the Dell Remote Access Windows setup screen?)
10) Software Manager Macrovision Company
11) ITunes AppleInc.
12) KTbWorks Application Kensington Computer
13) Logitech Vid HD Logitech Inc.
14) Logitech Camera Software "
15) Cyberlink PowerDVD CyberlLink Corp
16) PMSpeed NewSoft Technology
17) QuickTime Apple Inc.
18) CommonSDK Sonic Solutions
19) HD Audio Control Panel RealTek Semicon
20) Microsoft Windows Operating System Microsoft Corp (again?)
21) Skytel Unknown
22) Catalyst Control Center Advanced Micro
23) Java(TM) Platform SE Auto Updater 2.0 Sun Microsystem
24) Memo AutoBackup Memeo Inc
25) Windows Defender Microsoft Corp
26) WMPNSCFG Unknown
27) NsWrtMon Application NewSoft Technology Corp
28) InstallShield Macrovision Corp
MSCONFIG & Dell Remote Access
Can anyone tell me which of the entries listed in the original post is or are associated with the Dell Remote Access setup window?
