CaptainSTX
Part of the Furniture
While some VPN providers seem to recommend you use an MTU of 1500 PIA seems to recommend using a smaller MTU when using their service.
When I use PIA on my router and check my MTU it comes back at 1392 even though all my hardware is set at 1500.
I then added the following settings to my PIA configuration file:
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
I then re ran a series of speed tests and while the speed was slightly slower to the nearest PIA VPN server (200 miles ) to a more distant server (1200 miles ) the download speed increased by 14 Mbps or 8% at the 95% confidence level.
The strange thing though is when I checked my MTU after adding the above settings my MTU had decreased to 1360.
My question is what MTU are other PIA users using and does a setting an MTU really make any difference when you are using UDP?
tun-mtu 1500
tun-mtu-extra 32
mssfix 1450
