Mullvad + MerlinWRT "Error - check configuration!"
Numancia
Help... Getting "Error - check configuration!" when trying to connect MerlinWRT on Asus AX-88U with downloaded config file from Mullvad's OpenVPN config file generator for Android/ChromeOS as per their instructions https://mullvad.net/en/help/asus-merlin-and-mullvad-vpn/#instructions
I have no idea what is causing this because it used to work but I think Mullvad broke something in their OpenVPN config generator because even downgrading and fully resetting router is still causing this connection error message.
Check the system log, it will tell you why it's failing.
Here's the system log with 386.8 firmware, still at a loss as to what is causing the error though, any help would be greatly appreciated...
Nov 7 17:44:55 rc_service: httpd 1464:notify_rc start_vpnclient1
Nov 7 17:44:55 ovpn-client1[8397]: OpenVPN 2.5.7 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Aug 13 2022
Nov 7 17:44:55 ovpn-client1[8397]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.08
Nov 7 17:44:55 ovpn-client1[8398]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Nov 7 17:44:55 ovpn-client1[8398]: TCP/UDP: Preserving recently used remote address: [AF_INET]91.193.4.50:1301
Nov 7 17:44:55 ovpn-client1[8398]: Socket Buffers: R=[524288->1048576] S=[524288->1048576]
Nov 7 17:44:55 ovpn-client1[8398]: UDP link local: (not bound)
Nov 7 17:44:55 ovpn-client1[8398]: UDP link remote: [AF_INET]91.193.4.50:1301
Nov 7 17:44:55 ovpn-client1[8398]: TLS: Initial packet from [AF_INET]91.193.4.50:1301, sid=d776cfcd a35ce8e1
Nov 7 17:44:55 ovpn-client1[8398]: VERIFY OK: depth=2, C=SE, ST=Gotaland, L=Gothenburg, O=Amagicom AB, OU=Mullvad, CN=Mullvad Root CA v2, emailAddress=security@mullvad.net
Nov 7 17:44:55 ovpn-client1[8398]: VERIFY OK: depth=1, C=SE, ST=Gotaland, O=Amagicom AB, OU=Mullvad, CN=Mullvad Intermediate CA v4, emailAddress=security@mullvad.net
Nov 7 17:44:55 ovpn-client1[8398]: VERIFY KU OK
Nov 7 17:44:55 ovpn-client1[8398]: Validating certificate extended key usage
Nov 7 17:44:55 ovpn-client1[8398]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Nov 7 17:44:55 ovpn-client1[8398]: VERIFY EKU OK
Nov 7 17:44:55 ovpn-client1[8398]: VERIFY OK: depth=0, C=SE, ST=Gotaland, O=Amagicom AB, OU=Mullvad, CN=ch-zrh-304.mullvad.net, emailAddress=security@mullvad.net
Nov 7 17:44:55 ovpn-client1[8398]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bit RSA, signature: RSA-SHA256
Nov 7 17:44:55 ovpn-client1[8398]: [ch-zrh-304.mullvad.net] Peer Connection Initiated with [AF_INET]91.193.4.50:1301
Nov 7 17:44:56 ovpn-client1[8398]: SENT CONTROL [ch-zrh-304.mullvad.net]: 'PUSH_REQUEST' (status=1)
Nov 7 17:44:58 ovpn-client1[8398]: PUSH: Received control message: 'PUSH_REPLY,dhcp-option DNS 10.15.0.1,redirect-gateway def1 bypass-dhcp,route-ipv6 0000::/2,route-ipv6 4000::/2,route-ipv6 8000::/2,route-ipv6 C000::/2,comp-lzo no,route-gateway 10.15.0.1,topology subnet,socket-flags TCP_NODELAY,ifconfig-ipv6 fdda:d0d0:cafe:1301::100d/64 fdda:d0d0:cafe:1301::,ifconfig 10.15.0.15 255.255.0.0,peer-id 5,cipher AES-256-GCM'
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: compression parms modified
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: --socket-flags option modified
Nov 7 17:44:58 ovpn-client1[8398]: NOTE: setsockopt TCP_NODELAY=1 failed
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: --ifconfig/up options modified
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: route options modified
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: route-related options modified
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: peer-id set
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: adjusting link_mtu to 1625
Nov 7 17:44:58 ovpn-client1[8398]: OPTIONS IMPORT: data channel crypto options modified
Nov 7 17:44:58 ovpn-client1[8398]: Data Channel: using negotiated cipher 'AES-256-GCM'
Nov 7 17:44:58 ovpn-client1[8398]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Nov 7 17:44:58 ovpn-client1[8398]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Nov 7 17:44:58 ovpn-client1[8398]: GDG6: remote_host_ipv6=n/a
Nov 7 17:44:58 ovpn-client1[8398]: net_route_v6_best_gw query: dst ::
Nov 7 17:44:58 ovpn-client1[8398]: net_route_v6_best_gw result: via :: dev lo
Nov 7 17:44:58 ovpn-client1[8398]: TUN/TAP device tun11 opened
Nov 7 17:44:58 ovpn-client1[8398]: TUN/TAP TX queue length set to 1000
Nov 7 17:44:58 ovpn-client1[8398]: /usr/sbin/ip link set dev tun11 up mtu 1500
Nov 7 17:44:58 ovpn-client1[8398]: /usr/sbin/ip addr add dev tun11 10.15.0.15/16
Nov 7 17:44:58 ovpn-client1[8398]: /usr/sbin/ip -6 addr add fdda:d0d0:cafe:1301::100d/64 dev tun11
Nov 7 17:44:58 ovpn-client1[8398]: Linux ip -6 addr add failed: external program exited with error status: 2
Nov 7 17:44:58 ovpn-client1[8398]: Exiting due to fatal error
Did you remove the tun-ipv6 parameter from the configuration as directed in the Mullvad instructions?
Yes, this is my custom configuration at the bottom of the VPN Client page...
resolv-retry infinite
remote-cert-tls server
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
cipher AES-256-CBC
tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA
fast-io
remote-random
comp-lzo no
The problem appears to be that Mullvad are pushing IPv6 settings to the router. Is your router using IPv6?
Asuswrt-Merlin's OpenVPN client does not support IPv6. If your provider is pushing IPv6 options, you have to add config lines to tell your router to ignore them.
    pull-filter ignore "ifconfig-ipv6"
    pull-filter ignore "route-ipv6"
Not the only one having this issue...
Tried your suggestions as well as those under troubleshooting section (as per above post) for Mullvad with Merlin - "Exiting due to fatal error" / IPv6 issues / DNS leaks" but it didn't fix the issue. It is now "connecting" but says "connected to my ISP's IP - Internet not redirected"
I think my ISP, Videotron, may have changed something recently. According to this tweet people are having problems running a VPN with Videotron...
That's a different issue, and unrelated to your provider. As the message says, you did not tell your client to redirect the Internet traffic. There's a setting just a few options below that says "Redirect Internet traffic" that you need to configure.
ping 10
ping-restart 60
sndbuf 524288
rcvbuf 524288
cipher AES-256-CBC
fast-io
remote-random
comp-lzo no
I don't see where you inserted the config to ignore IPV6
In addition, check the server name/IP you are connecting to - Mullvad has been changing some servers lately.
Same error happening here using the same router as you. I think the issue is with Mullvad as when I use IVPN's ovpn config there is no issue.
Try changing/adding the following in the Custom Configuration field:
replace proto udp with proto udp4.
replace proto tcp with proto tcp4.
add pull-filter ignore "route-ipv6"
add pull-filter ignore "ifconfig-ipv6"
This certainly did the trick! Thank you!
Thank you, adding these two lines to my custom configuration fixed my problem.
I also upgraded my AX-88U with the latest firmware 388.1 and noticed there is now a tab for Wireguard under VPN -> VPN Client... Do you know if someone has created a setup guide for Merlin with Wireguard and Mullvad VPN, can't find it on their site.
