Hello everybody !
Since a few weeks, my Mullvad-VPN-connection did not work any more.
I asked the Mullvad-Service for help and was sending the "system-log".
Here is the answer I got:
It seems openvpn thinks you have IPv6 enabled on the router, but
the ip command thinks otherwise. You can read here how to disable ipv6
completely if you do not manage to get it to work:
http://askubuntu.com/questions/4403...-to-an-openvpn-server-using-network-manager-o
Now here is my question: is it possible to deacitvate ipv6 on the RT-N66U without manipulating the kernel ?
Any answer is appreciated.
Thanks Garry13
Here is my system.log:
Mar 23 17:05:42 rc_service: httpd 4922:notify_rc start_vpnclient1
Mar 23 17:05:43 openvpn[5046]: OpenVPN 2.3.6 mipsel-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Mar 6 2015
Mar 23 17:05:43 openvpn[5046]: library versions: OpenSSL 1.0.0q 15 Jan 2015, LZO 2.08
Mar 23 17:05:43 openvpn[5046]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mar 23 17:05:43 openvpn[5046]: Socket Buffers: R=[118784->131072] S=[118784->131072]
Mar 23 17:05:43 openvpn[5048]: UDPv4 link local: [undef]
Mar 23 17:05:43 openvpn[5048]: UDPv4 link remote: [AF_INET]46.21.99.25:1194
Mar 23 17:05:43 openvpn[5048]: TLS: Initial packet from [AF_INET]46.21.99.25:1194, sid=f87379b4 ad9949c6
Mar 23 17:05:43 openvpn[5048]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Mar 23 17:05:43 openvpn[5048]: VERIFY OK: depth=2, C=NA, ST=None, L=None, O=Mullvad, CN=Mullvad CA, emailAddress=info@mullvad.net
Mar 23 17:05:43 openvpn[5048]: VERIFY OK: depth=1, C=NA, ST=None, L=None, O=Mullvad, CN=master.mullvad.net, emailAddress=info@mullvad.net
Mar 23 17:05:43 openvpn[5048]: Validating certificate key usage
Mar 23 17:05:43 openvpn[5048]: ++ Certificate has key usage 00a0, expects 00a0
Mar 23 17:05:43 openvpn[5048]: VERIFY KU OK
Mar 23 17:05:43 openvpn[5048]: Validating certificate extended key usage
Mar 23 17:05:43 openvpn[5048]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Mar 23 17:05:43 openvpn[5048]: VERIFY EKU OK
Mar 23 17:05:43 openvpn[5048]: VERIFY OK: depth=0, C=NA, ST=None, L=None, O=Mullvad, CN=se1.mullvad.net, emailAddress=info@mullvad.net
Mar 23 17:05:44 openvpn[5048]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1558', remote='link-mtu 1542'
Mar 23 17:05:44 openvpn[5048]: WARNING: 'cipher' is used inconsistently, local='cipher AES-256-CBC', remote='cipher BF-CBC'
Mar 23 17:05:44 openvpn[5048]: WARNING: 'keysize' is used inconsistently, local='keysize 256', remote='keysize 128'
Mar 23 17:05:44 openvpn[5048]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mar 23 17:05:44 openvpn[5048]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mar 23 17:05:44 openvpn[5048]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mar 23 17:05:44 openvpn[5048]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Mar 23 17:05:44 openvpn[5048]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Mar 23 17:05:44 openvpn[5048]: [se1.mullvad.net] Peer Connection Initiated with [AF_INET]46.21.99.25:1194
Mar 23 17:05:47 openvpn[5048]: SENT CONTROL [se1.mullvad.net]: 'PUSH_REQUEST' (status=1)
Mar 23 17:05:47 openvpn[5048]: PUSH: Received control message: 'PUSH_REPLY,ifconfig-ipv6 fd07:698a:921f:8::1027/112 fd07:698a:921f:8::,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.8.0.1,route-ipv6 0000::/2,route-ipv6 4000::/2,route-ipv6 8000::/2,route-ipv6 C000::/2,route-gateway 10.8.0.1,topology subnet,ifconfig 10.8.0.41 255.255.0.0'
Mar 23 17:05:47 openvpn[5048]: OPTIONS IMPORT: --ifconfig/up options modified
Mar 23 17:05:47 openvpn[5048]: OPTIONS IMPORT: route options modified
Mar 23 17:05:47 openvpn[5048]: OPTIONS IMPORT: route-related options modified
Mar 23 17:05:47 openvpn[5048]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mar 23 17:05:47 openvpn[5048]: TUN/TAP device tun11 opened
Mar 23 17:05:47 openvpn[5048]: TUN/TAP TX queue length set to 100
Mar 23 17:05:47 openvpn[5048]: do_ifconfig, tt->ipv6=1, tt->did_ifconfig_ipv6_setup=1
Mar 23 17:05:47 openvpn[5048]: /usr/sbin/ip link set dev tun11 up mtu 1500
Mar 23 17:05:47 openvpn[5048]: /usr/sbin/ip addr add dev tun11 10.8.0.41/16 broadcast 10.8.255.255
Mar 23 17:05:47 openvpn[5048]: /usr/sbin/ip -6 addr add fd07:698a:921f:8::1027/112 dev tun11
Mar 23 17:05:47 openvpn[5048]: Linux ip -6 addr add failed: external program exited with error status: 2
Mar 23 17:05:47 openvpn[5048]: Exiting due to fatal error
Thanks Garry13
