Multi-function DIY NAS w configurable selective Low Sleep/ Disk Spin down abilities?
crashnburn
Essentially I'd to build a low Power NAS. Especially, when it sleeps.
Functionality:
1) Primary Usage:
- NAS/ Media Server:
Primary Usage - Some selective ability to Sleep all Disks/ Drives that contain most of the MEDIA, until actually being used. Kind of like an extended functionality of WOL (Wake on LAN), Wake on Use.
Sleep/Wake on Use: MEDIA STORAGE Disks
2) Secondary Usage:
- Download / Torrent/ Seedbox:
Secondary Usage - Ability to keep awake selective disk(s) for Torrent Download and Seed purposes. Selectively keep awake or Sleep the DOWNLOADING/ SEEDING Disks.
Sometimes, I like to download things but don't want entire set of MEDIA DISKS to be awake & consuming power.
I only have a 2 MBps (150-200kb/s) (may upgrade to 4) downloads at Maximum capacity on Torrents. So, wont be needing some really high strength CPU. Prefer a CPU/ Board with Low Power profile.
3) Tertiary Usage:
- PXE Server:
This is not crucial but would be nice to have the ability to Network Boot of certain ISOs using a PXE Server.
Simple, Fast and Power Efficient NAS...?
Nas OS Comparison (unRaid, eon, Freenas,...)
Inching toward the NAS of our dreams
Wanted: Cheap giant bit barrel
The USB-drive time bomb
Having read the above discussion I'd like to know thoughts on the following:
1. What kind of CPU/ Motherboard combination would be good for the above scenario? Assuming I will be adding storage as I can buy more.
2. Box/Case Profiles: (Not critical)
3. Operating System / File System / Add-on Apps/Utlities Combination for Controlling and Automating Wake/Sleep for different HDD/ Disk Groups (MOST CRITCAL THOUGHTS):
A) Ability to Segregate the Disks in Groups and apply varying POWER PROFILES to them (Sleep/Awake/Power down).
WAKE/SLEEP them as needed using some Control Panel or Software/ Application / SCRIPTING/ Hack/Mod tools available on the given OS being used for the NAS.
1- MEDIA STORAGE DISKS: Sleep most of the time. Rare usage when watching/ streaming media or migrating media on/off it.
2- DOWNLOAD/ SEEDING DISKS: Sleep lesser than above MEDIA disks. Be used occasionally as Download/ Seeding space, staying AWAKE while letting the MEDIA STORAGE Disks sleep
3- PLAYGROUND:
PXE Server DISKS: Be able to WAKE/SLEEP them as needed.
Disks for Experimental Use/ Play with OSes (Rare case when I disconnect the A & B Disks and just play with new stuff on the box)
B) DATA RECOVERY & INTERNAL MIGRATION (File System Compatibility):
-I've had scenarios where HDDs have died on me so ability to read the file system independently of the Original NAS OS will help.
- There are times I am using an External USB HDD and once I have a bunch of the data organized I'd like to maybe just PLUG it INSIDE the NAS Box (via SATA/PATA) to MIGRATE some of the Data off the Disk to Storage on the NAS (Or maybe the opposite someday). This could bypass the bandwidth limitation of USB2.0/ lack of eSATA on some of my USB drives/ enclosures.
Typically, the External USB drives end up being NTFS/FAT32 so an OS / OS driver/ Plugin/ Mounter that has the ability to READ the "INSERTED" drive/ partition and copy the data would be great.
Hi there,
You can control the individual drives' power scheme (e.g. standby time) under Linux with hdparm.
Reading and writing NTFS is not a problem under Linux anymore.
If you're comfortable with the command line and scripting, Linux is IMO the way to go.
Cheers.
P Questions on my first DIY NAS (+server) build DIY 14
