Multi-purposing unifi devices
3Greens
I have a number of unifi devices in my home, including USG, CK2, APs.
I also have a RaspberryPi running a number of things, e.g. PiHole, Homebridge, etc.
As I find the RPi quite unreliable (and have struggled to get it to boot from a SSD), I was wondering if there is a precedent for installing some of these applications on the Unifi hardware? Would there be anything stopping you from SSHing into the CK and installing PiHole or AdGuard? Are there other Unifi components within the above that could also be dual purposed as I guess you can SSH into any of them? Are there risks associated with this? It strikes me that the CK2, in particular, is quite powerful and more than adequate to run more than the controller software.
Could the controller software even be installed on the USG? Just to push the boat out!
No. Instead of using RPi and SD cards (usually the unreliable part), get an used mini PC from eBay and run whatever Linux version you need on it. It will be much faster/reliable and the same cost as RPi 4 kit. Your USG is very slow hardware, it tanks below 100Mbps WAN-LAN with QoS. Your CK2 is purposely built hardware. You can't do anything on the AP's. Leave UniFi doing what it does best, offload other services to better dedicated hardware.
