Multi source selective port forward?
eastavin
Hello. I have a need to forward several ports for a gaming PC. This works well so far on my rt-ax86u on the latest Merlin FW.
I see when setting up port forwarding one can add a source IP to make the forwarding selective. Is it possible to enter more than one source IP in this field? Like say 12 source IPs maybe? That would be ideal.
If it's not possible on this screen is there another method?
Many thanks
Edward
If they are within the same subnet, you can specify the source IP in CIDR format. Otherwise, you will need one forward rule per source IP.
