I have read for days on the topic ... I have alot of "special" circumstances where I require 2 DSL lines to be "bonded" together using MLPPP ... I already own and love the RT-N66U router running asusmerlin firmware. This is capable of DUAL Wan in load balance but does not bond the connections.
there are alot of rural folks out there that need the extra speed like myself. I work from home and have no other options then using 2 DSL connections or more.
Merlin any chance you would be interesting in developing support for this?
I hate to downgrade to a cheaper router that supports tomato/mlppp
If I run a second router it presents new challenges such as the built in ASUS DDNS will no longer function (I believe) because it will be behind the tomato router.
Any one else have experience with this type of setup?
