Diversion Multiple Dnsmasq IP's for alternate blocking list / Excluding devices causing issues
ComputerSteve
So I have noticed that a hostname problem starts if I enable these options::: alternate Dnsmasq IP 192.168.50.4 / Exclude devices from ad-blocking enabled on 192.168.50.3 -- I use my router for time machine backups, and with these options enabled for Diversion I see this in the logs. This keeps happening until eventually it changes my assigned hostname of AX86U-DEN-418 to one with a different number at the end.. I can fix this problem by running this command service restart_timemachine after it finally settles on the hostname. I wan't to know if theres a fix though for this or a way to make this stop happening ::: I appreciate all your work on this great adblocker @thelonelycoder !
Mar 24 12:42:16 avahi-daemon[4024]: Host name conflict, retrying with AX86U-DEN-432
Mar 24 12:42:16 avahi-daemon[4024]: Registering new address record for 192.168.50.3 on br0.IPv4.
Mar 24 12:42:16 avahi-daemon[4024]: Registering new address record for 192.168.50.4 on br0.IPv4.
Mar 24 12:42:16 avahi-daemon[4024]: Registering new address record for 192.168.50.2 on br0.IPv4.
Mar 24 12:42:16 avahi-daemon[4024]: Registering new address record for 192.168.50.1 on br0.IPv4.
Mar 24 12:42:16 avahi-daemon[4024]: Registering new address record for 127.0.1.1 on lo.IPv4.
Mar 24 12:42:16 avahi-daemon[4024]: Registering new address record for 127.0.0.1 on lo.IPv4.
Mar 24 12:42:17 avahi-daemon[4024]: Withdrawing address record for 192.168.50.3 on br0.
Mar 24 12:42:17 avahi-daemon[4024]: Withdrawing address record for 192.168.50.4 on br0.
Mar 24 12:42:17 avahi-daemon[4024]: Withdrawing address record for 192.168.50.2 on br0.
Mar 24 12:42:17 avahi-daemon[4024]: Withdrawing address record for 127.0.1.1 on lo.
Mar 24 12:42:17 avahi-daemon[4024]: Withdrawing address record for 127.0.0.1 on lo.
Mar 24 12:42:17 avahi-daemon[4024]: Host name conflict, retrying with AX86U-DEN-433
Mar 24 12:42:17 avahi-daemon[4024]: Registering new address record for 192.168.50.3 on br0.IPv4.
Mar 24 12:42:17 avahi-daemon[4024]: Registering new address record for 192.168.50.4 on br0.IPv4.
Mar 24 12:42:17 avahi-daemon[4024]: Registering new address record for 192.168.50.2 on br0.IPv4.
Mar 24 12:42:17 avahi-daemon[4024]: Registering new address record for 192.168.50.1 on br0.IPv4.
Mar 24 12:42:17 avahi-daemon[4024]: Registering new address record for 127.0.1.1 on lo.IPv4.
Mar 24 12:42:17 avahi-daemon[4024]: Registering new address record for 127.0.0.1 on lo.IPv4.
Search the forum. I remember this problem with avahi-daemon being reported multiple times over the years. I can't remember whether or not there was a resolution.
