Multiple SSIDs forwarding to multiple VPNs
ufoolme
Hi all,
Is it right to assume I could create multiple openvpn tuns and use then iptables/ufw (or similar) to forward different SSIDs to different openvpn connections?
I should be able to work out the specifics myself, but would prefer to know if this is possible before shelling out for the ac3200.
Background:
I have been investigating getting a new router to handle my VPNs. I have a number of servers in different parts of the world, and I would like to be able to change between VPNs on all my devices via by changing wireless instead of manually configuring each computer/vm/mobile device.The asus range or routers looks good and if I couldn't get it working with the vendor firmware, then the merlin looks like the answer.
Thanks in advanced!
