Multiple vpn servers
Make
Hi Guys,
I've setup 2 OpenVPN servers and when e.g. phone is connected to 2nd server, I cannot reach out the 1st server clients.
Any advice what I could do and how?
OpenVPN server 1: 10.0.5.0 / 255.255.255.0
OpenVPN server 2: 10.0.6.0 / 255.255.255.0
And another thing; when "Username/Password Authentication" is enabled and "Username / Password Auth. Only" is not enabled --> client specific settings can be done in Common name level. Problem is that all has same common name "client" (see screenshot).
If I enable "Username / Password Auth. Only" --> then client specific settings can be done in username level.
Hi Guys,
https://i.imgur.com/zjQKx55.jpg
https://i.imgur.com/n2mcX5Y.jpg
https://i.imgur.com/TXcf3QL.jpg
Not sure if this applies to your certain case but configured my AC86U OpenVPN Gateway Server as detailed above.
By using TAP>TUN creates the bridge connection necessary for OpenVPN Server 2 remote connected clients to be able to ping / browse shares / remote desktop into OpenVPN Server 1 connected clients and vice versa as successfully configured on my OpenVPN Gateway Server to use TAP / UDP via port 1194 for OpenVPN Server 1 settings and TAP / UDP via port 389 for Server 2 settings.
By configuring the AC86U OpenVPN Gateway Server this way allows ALL clients on both OpenVPN servers to exist on a single LAN with no additional firewall rules required and achieve the possible throughput detailed below!;)
https://i.imgur.com/1ORcgLZ.png
https://i.imgur.com/hv2LARi.jpg
End to end TAP udp via port 1194 OpenVPN tunnel throughput pictured above of XMission's Utopia active ethernet fiber network 1 Gbps up/down throughput on both ends.
https://i.imgur.com/z3vpFiE.png
https://i.imgur.com/2jU9pZ3.jpg
Pictured above is the normal https://xmission.com/utopia throughput attained on either end of this test over the Utopia fiber network...
FWIW: RT-AC86U gateway OpenVPN Server router is able to achieve the above throughput for remote OpenVPN clients running under Merlin's latest RT-AC86U_384.6_alpha2-g5b076fc87 test build...
Thanks for the answer.
I tried but I'm not able to connect android device when using TAP, also the internet traffic will increase.
I've added below rows to Custom Configuration box, but still not able to connect from 2nd server client (10.0.6.0 255.255.255.0):
push "route 10.0.5.0 255.255.255.0"
push "route 10.0.2.0 255.255.255.0"
push "dhcp-option DNS 10.0.5.1"
push "dhcp-option DNS 10.0.2.1"
