Hello, I have a RT-AC68U / AsusWRT-Merlin 384.6 and would like to use the 5 available client slots for vpn. Unfortunately, I cannot figure out how to use them, specifically, how to switch from one to another!
For now I have 2 VPN client credentials in slot 1 and 2 respectively.
Slot 1 works well, it is also configured as "connect on boot". This connection is stable and works.
Then I configured slot 2. As the VPN Provider is the same as for slot 1, I mirrored the data and cannot imagine I left something out. Of course, I used a different server / ovpn file!
Now this is the situation:
I would like to change the client. What steps do I take? I tried deactivating slot 1, change to slot 2 and activate that. That did not work. Next I did the same, but after each step I scrolled down to apply the settings. That did not work either. At this point I am not getting any connection whatsoever and I have to restart the router and client 1 is active again (connect on boot)
Can someone tell me the exact steps I need to take to successfully change from one client to another?
Many thanks in advance!!
