Moogle Stiltzkin
Ok i am using the latest firmware ( not beta ).
I installed joomla, phpMyAdmin, Optware-ipkg, Python, rtorrent++ and Perl.
-joomla = manage to install but.... to access the website it's linked to http:///Joomla
How do you make it so that the Joomla page will show when you just put http://My Nas Ip address ?
- phpMyAdmin = couldn't access at first using the default password and username. I however went to the mysql page in QNAP and reseted it, and the default worked. I successfully created a mysql which was used for Joomla.
- rtorrent++ = installed the QPKG package that Silas did. Wouldn't work until i realised you need to set the service as enabled, a green message would indicate it is. It comes with 3 web gui templates. Wtorrent can't work for some reason, anybody know why ? The other work fine, but the speeds are slow but that is probably my ISP and also some torrent settings need to be fine tuned.
