bwana
I have a netgear R7000 that works ok. The network is 192.168.9.0 and the router ip is 192.168.9.9 Recently I attached a NAS via ethernet cable that was from a different LAN and its address is 192.168.7.5 Surprisingly, when i look at attached devices the NAS shows up with its ip address even though it is not addressable on the LAN. Any attempt to find it by using a laptop attached wirelessly to the LAN and logging into it with a browser, or scanning the network is unsuccessful. Same when i try to use an ether net conneccted pc. However I can change the ip address of the pc to 192.168.7.whatever (leaving the gateway blank on the ipv4) and i can open the nas and log into it from a browser. Of course everything else on the LAN is not seen as well as no internet.
Why does the NAS show up in the router but is not 'navigable to' unless i change the ip of the pc? How does the pc 'know' the nas if there is no gateway to negotiate the connection? I am only giving the pc an ip address so how does it know the mac address of the nas to talk to it?
Can I keep the nas with its 'foreign' ip address on the new lan by configuring a static route? (whatever that is-I still do not understand what is going on under the hood of the router when i specify a static route)
