SOLVED - thanks for the help!
I'm having trouble flashing an RT-AC68P. (This unit uses the same firmware as the AC68U.) Right now my unit is booting up into the ASUSTek CFE miniWeb Server. From there I have tried flashing Merlin builds 384.6 and 384.7. I have also tried stock Asus firmware and two recent dd-wrt builds.
I prefer the Merlin 384.7 build, but that this point I am just trying to get any non-stock firmware to flash successfully.
I was previously running RT-AC68U_3.0.0.4_378_8258-g847cc77.trx, and my problems started when I tried to flash a standard dd-wrt build betas_2018-10-04-r37139_asus_rt-ac68u-firmware.trx. I flashed that through the web GUI. Since then, I have mostly not been able to get past the CFE miniWeb Server.
After some time, I did manage to reflash RT-AC68U_3.0.0.4_378_8258-g847cc77.trx successfully again. Then I double checked my steps and tried a Merlin build again, and once again I cannot get past the CFE miniWeb Server.
I have 2 other routers running dd-wrt - TP-Link Archer C7 v4, Netgear R7000. I had no problems flashing those. Also, a while back I was running dd-wrt on this exact same device. Any suggestions for resolving my current issues with flashing a Merlin build to the RT-AC68P?
Some things I have tried without success:
RT-AC68P Firmware Upgrade Issues | SmallNetBuilder Forums http://www.snbforums.com/threads/rt-ac68p-firmware-upgrade-issues.28252/
I was not able to tell exactly if I need to flash an older Merlin build before flashing 384.7 (from the latest stock Asus firmware). Could that be my problem?
- With and without the 30/30/30 reset
- Waiting 30 minutes after flashing before rebooting (still never saw the WLAN lights come on)
- Let it sit powered off overnight
- Reboot multiple times
- Re-downloading the firmware images to be sure they are not corrupted
- Re-reading so many posts that now I'm confused.
