N66 to 1900P - reuse config?
hifiwifi
Upgrading to a 1900P. Is it advised to use the same saved config, or is this even possible? Risks? Thanks.
No, you must not load a config file from another router.
It is recommended that you set things up from scratch but if you don't want to you can use John's NVRAM utility in "migration" mode.
