Started last night. First the n66U. I would make a change such as SSID channel or added an IP on the reserved list and then hit apply. The router would hang at "Processing" busy cursor and never recover. Sometimes the change was a little as changing a description field in L2TP record. I ended up doing a factory reset and this router seems ok now.
Then, this afternoon, my AC66U started behaving weird. I tried to select a Radio frequence (5 Ghz in this particular case) and I would get a error page with a "No Data Received" box in the middle. Tried to "Clear" the System log and got the same message. Clicked the Reboot button. Nothing happened. No error or anything. Powered it down and restarted it again. Tried to make a change and hit apply. Same thing as the N66U. The "Processing" stay on indefinitely. What is going on??
AC66U - FW:3.0.0.4.374.38_2
N66U - FW:3.0.0.4.374.40
