N66U Changing Lan IP
g1dtf
If I change the Lan IP on my N66U (Rmerlin FW) from 192.168.1.1 to 172.16.2.254 will I also need to change the DHCP server settings accordingly as I dont want to lose access to router from my attatched devices.
Changing the router's LAN IP address will automatically change the DHCP pool starting and ending addresses (using the default range). However, if you have any "manual assignments" they will not be changed.
Thanks I do have manual assignments but I can change them if needed after I have done my test.
