N66U OPENVPN Server helpp
Bolded
Hello,
I have setup my openvpn server its on and enabled.
I am using my IP Address to connect instead of dns
Below are my settings
I also port forwarded the below see pic
Everytime i try to connect with my laptop connected to my phone for a different network this is where im getting stuck at see below
http://pastebin.com/uqusqfuG
any suggestions as to what im doing wrong?
thanks
  1. You don't need to specify port forwarding for 1194.
  2. Make sure you have entered your Keys on the OpenVPN Keys Tab.
The only other differences I see between your settings and mine are:
  • Direct clients to redirect Internet traffic - I've set to Yes
  • Under System Configuration, I have added 'server-bridge 172.21.59.1 255.255.255.0 172.21.59.245 172.21.59.254'
One other quick note: it's generally easier easier to get TUN working (as opposed to TLS) because you don't need to worry about the DNS/networking classes (or that server-bridge setting). I tried getting TUN working first before I moved onto TLS...
Ok changed it to tun
Removed port forwarding
enabled direct clients to redirect traffic
can i post a screenshot of my keys to show ive entered it properly?
After changing these settings still the same wont connect..
IT WORKEDDDD after removing the port forward !!!
Awesome thank you for that
i was able to access my freenas and my router and sabnzbd via my phone's net
thanks again
One last question.
Can i have my VPN Server ON and my VPNClient connected to PIA and connect remotely to my wan ip not the PIA ip ?
