N66u Parental Controls <380.57
Littledave
I have the N66u at the moment running .57 firmware.
Anything above the and parental controls do not work and cannot be edited. The settings page does not load properly. Also I keep getting returns the the login page.
Looking at the log I see the watchdog restarting.
Also the Asus router app only works with the firmware .59 and not below.
Thanks for letting us know and welcome to the forums. :)
Have you performed a reset to factory defaults after flashing a different firmware? Followed by a minimal and manual configuration of the router to secure it and connect to your ISP?
http://www.snbforums.com/threads/no...l-and-manual-configuration.27115/#post-205573
A safe method of keeping a good record of all your settings (and a very high chance of actually transferring them successfully between different firmware versions) is by using john9527's excellent NVRAM Save/Restore utility.
http://www.snbforums.com/threads/user-nvram-save-restore-utility-r24.19521/
It will also probably be a good idea to all the above, to clear your browser cache too and even test using a different browser.
I hope the above works. And I hope that is the questions you were thinking of asking too (I took a wild guess). :)
