D
Deleted member 27741
Guest
I have been having an odd issue with QOS. In order to get it to "work" I have to enter a very small download speed.
I want to use QOS on my ~150 Mbps down/10 Mbps up connection. Wireless frequency 5.0 Ghz. In order to see low pings while doing anything else, I have to enter my speed in QOS as about 10-20 down/10 up. User-defined priorities does have ack,syn,fin,rst, and icmp checked.
Does anyone use QOS for an interface and it works? Perhaps I am entering something wrong. My only QOS rule is the following:
Service name: wi-fi
Source IP or MAC: selected the ip address of the 5.0 Ghz interface (set as static address in dhcp) I wish to be at the front of the line
Destination port: empty
Protocol: any
Transferred: empty
Priority: Highest
The way I have been testing this is to test speed at speedtest.net and look at my ping to the router during the test. Also tried iperf3 from router to computer I want QOSSED. Both raise the latency of the router by hundreds of milliseconds while the connection is using little of its download capacity. Perhaps this is normal and I'm a dummy.
P.S.- upload QOS seems to function fine. If someone has QOS working on a mac address on an N66U with 374.43_32E4j9527 firmware running, let me know what black magic I am missing.
Service name: wi-fi
Protocol: any
Transferred: empty
Priority: Highest
