thinkpadfan
I have a Asus N66U running a very old Merlin Firmware, version 3.0.0.4.270.26
All works fine but wish to update to current firmware version.
I have been looking for detailed step-by-step instructions in the Best Practices to install the new firmware.
1) Download current firmware, login into router's GUI and make screengrabs or notes on the current configuration settings.
2) remove ethernet cable from cable modem and pull power to cable modem
3) remove other ethernet cables from router except for the one attached to whatever computer will doing the update firmware from.
This is where I get confused. I see talk of clearing NVRAM via using the WFS button on the router combined with a process of pulling the power cord; and found this forum post but was confused by the term of "Recovery Mode"
- Unplug the power of the router
- While plugging the power back in, hold the WFS Button (to clear the NVRAM)
- The power LED is flashing, then it took command and will clear the NVRAM
- After releasing WFS, all of the LEDs light up. This is when you start holding the Reset button.
- If you did this correctly, the Power LED will be flashing on and off, slowly. This means you have accessed recovery mode.
Is "Recovery Mode" the same as "Factory Default" ?
** Bottomline: I am seeking clear, detailed step-by-step Wiki instructions on updating very old Merlin firmware to current firmware on an Asus N66U (version B1 if that matters)
I simply prefer to ask for help BEFORE doing something I do not understand vs. seeking help after I screw something up
Thank you
Thank you
