naming devices on routers web interface?
Gunner84
Hi
Is it possible to name devices that show up on the network map page where it lists all devices connected via wired or wireless.
Some tell me already such as ipad but I have a few android and other devices that just show the IP address and I can never tell which is which!
Is it possible if so how?
thanks
*running latest 374.43 merlin fork.
Hi
thanks
Yes, you can, but on the fork you need to set it up manually. I use this method to replace the crazy name of my android tablet.
See this post
http://www.snbforums.com/threads/fork-update-for-374-43-available.18914/page-55#post-167647
@Gunner84 Welcome to the fork :)
I should have mentioned that you can do the same thing via assigning a static ip if you don't want to play with the conf.add, but that was also referenced in the post.
