jl_678
I am an active photographer and am rapidly running out of disk space on my primary system. Historically, I have used a Linux box with Samba to provide disk storage, but it is almost maxed out (only 250 GB total cap.) and I have decided to go to a purpose built NAS solution.
I am looking at 4 bay models because I need the scalability. I am typically pushing 20 MB image files and anticipate this increasing to about 35 MB shortly. The key goal is the ability to rapidly read and write these image files to the NAS box in the basement. I also would like easy expansion (both physical disk and RAID) because the nature of photography is that you can never have enough space and so it will be a question of when I add capacity not if.
I have looked at so many options here at SNB and am a bit overwhelmed. Being a bit of techie, I have been impressed the ReadyNAS NVX and its performance and XRAID2. Of course, it is expensive, but at about $1,000 for the 2 TB version with enterprise drives, it does not seem as outrageous as it once was. I have also considered the Synology DS-409+. Which brings me to my questions:
What do the experts here think would be the best choice for me?
Would I really notice the increased speed of the NVX? (Note I do have a GigE wired LAN)
Are there other options that I should consider?
Thank you!
JL
Thank you!
JL
