Hi Guys,
Having to upgrade the size of my NAS, I've decided to quickly review the different OS solutions.
My NAS hardware is the following:
My client is the following:
I want to test unRaid, EON, Freenas and Ubuntu, all at the latest version (even if beta/alpha)
The test will be only on CIFS.
I've created a 31G file using dd (dd if=/dev/zero of=./zerofile.tst bs=1k count=30000000)
it has taken 344,2s to do it (681 Mb/s rate).
edit: I've created a 10G randomized file using dd too (dd if=/dev/urandom of=./randomfile.tst bs=1k count=10000000)
edit2: I've also created a 10G file filed with zero in order to speed up the tests (dd if=/dev/zero of=./zerofile.tst bs=1k count=10000000)
all the following test will be done using the same behavior.
First mount of the share on the nas with default options (mount -t cifs //NAS_IP@/share /mnt/cifs -o user=sylvain,pass=xxx)
First copy of the file on the nas (time cp zerofile.tst /mnt/cifs)
The copy of file from the nas (time cp /mnt/cifs/zerofile.tst .)
edit: Then do the same thing with the random file
Specific things done on the nas will be described on the different part
unRaid Part
Tests with unRaid 5.0 beta2
parity disk is the one on the sil card
No specific things except that (used the Webpage to administer the nas).
Surprinsingly, reading takes longer time than writing...
E.O.N Part
Tests with eon 0.60
ZFS with Gzip-1 Compression and deduplication
command passed to create the filesystem (viewed on the eon site of course )
zpool create tank raidz c1t0d0 c2d0 c3d0
zfs create -o casesensitivity=mixed -o sharesmb=on tank/media
zfs set sharesmb=name=media tank/media (create a ZFS filesystem = media on zpool = tank, casesensitivity has to be set at creation)
cd /tank ; chmod 755 media (set permission to full control for owner and read, execute for group and others)
groupadd -g 600 media
useradd -u 501 -g 600 -s /bin/bash sylvain
cd /tank ; chown sylvain:media media (set owner = sylvain and group = media on the tank/media dataset)
chmod A+owner@:full_set:fd:allow,everyone@:read_set/execute:fd:allow media (for proper unix permission inheritance on windows created files)
zfs set compress=gzip-1 tank/media (optional: enable gzip-1 compression, a good balance of compression ratio and performance)
zfs set dedup=on tank/media (optional: enable deduplication on dataset tank/media. dedup=on is the same as dedup=sha256,verify)
passwd sylvain (set the passwd for sylvain also so that it will be recognized for CIFS login)
smbadm join -w workgroup
eon:62:/tank/media#zpool status
pool: tank
state: ONLINE
scrub: none requested
config:
NAME STATE READ WRITE CKSUM
tank ONLINE 0 0 0
c1t0d0 ONLINE 0 0 0
c2d0 ONLINE 0 0 0
c3d0 ONLINE 0 0 0
errors: No known data errors
eon:63:/tank/media#zpool list
NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT
tank 4.08T 123K 4.08T 0% 1.00x ONLINE -
Surprinsingly again, reading takes longer time than writing...
The good thing is the compression that make the 30G file virtually empty (of course in real life it won't happen).
ZFS without Compression and deduplication
The command are the same except the two on media which activates compression and deduplication
Freenas Part
I wanted to use Freenas 0.8alpha but never managed to make it boot (issue with mounted file system).
So the tests are done with Freenas 0.7.2.5266 (RC version)
Everything is done via the Web page
UFS
ZFS without compression
ZFS with lzjb compression
ZFS with gzip-1 compression
As we can see, compression can significantly increase performance if the file to be compressed can be easily compressed.
ubuntu Part
I've used ubuntu server 10.10 beta installed on an usb key (using ext4 for the system).
the share is install on a software raid5 made with md during installation. On top of this raid5, I've used ext4 or btrfs
ext4
Btrfs no compression
Btrfs Compression
I was really surprised with write speed using ext4 (i did several times the test to be sure...).
Conclusion
Heres the numbers:
As you can see, EON is far behind (perhaps Sun's SMB implementation is not good) and the three others are quite close.
My opinion is then the choice of paid os (unRaid) or free os (freenas) knowing that the unique feature of unRaid is very very interesting!
Personaly, I think I'll go with unRaid.
- Intel D945GCLF2 (Atom 330 1.6Ghz Bi Processor Hyperhtreading, i.e. 4 vCPUs -- 2 physical, 2 "virtuals")
- 2G RAM
- OS on USB Disk
- Realtek Gbe NIC
- one Sil3124 card (4 SATAII ports on 1 PCI slot)
- 3 1,5To Samsung disk (two on the board sata ports, one on the Sil3124)
- Intel Core 2 Quad Q9550
- 4G of RAM
- Asus P5K Motherboard
- Intel 82574L Gbe Nic
- Ubuntu 10.04 OS on disk
unRaid Part
- Zero File
- Write: 271Mb/s
- Read: 211Mb/s
- Random File
- Write: 241Mb/s
- Read: 213Mb/s
E.O.N Part
Tests with eon 0.60
pool: tank
state: ONLINE
config:
tank ONLINE 0 0 0
c1t0d0 ONLINE 0 0 0
c2d0 ONLINE 0 0 0
c3d0 ONLINE 0 0 0
- Zero File
- Write: 307Mb/s
- Read: 90Mb/s
- Random File
- Write: 80Mb/s
- Read: 69Mb/s
- Zero File
- Write: 147Mb/s
- Read: 92Mb/s
- Random File
- Write: 150Mb/s
- Read: 92Mb/s
Freenas Part
UFS
- Zero File
- Write: 235Mb/s
- Read: 150Mb/s
- Random File
- Write: 228Mb/s
- Read: 147Mb/s
- Zero File
- Write: 176Mb/s
- Read: 187Mb/s
- Random File
- Write: 178Mb/s
- Read: 172Mb/s
- Zero File
- Write: 9481Mb/s
- Read: 143Mb/s
- Random File
- Write: 153Mb/s
- Read: 183Mb/s
- Zero File
- Write: 10417Mb/s
- Read: 143Mb/s
- Random File
- Write: 85Mb/s
- Read: 180Mb/s
ubuntu Part
ext4
- Zero File
- Write: 9413Mb/s
- Read: 216Mb/s
- Random File
- Write: 295Mb/s
- Read: 198Mb/s
- Zero File
- Write: 365Mb/s
- Read: 198Mb/s
- Random File
- Write: 303Mb/s
- Read: 189Mb/s
Btrfs Compression
- Zero File
- Write: 10557Mb/s
- Read: 213Mb/s
- Random File
- Write: 288Mb/s
- Read: 194Mb/s
Conclusion
Heres the numbers:
