Naftali Oziel
two questions
1. Do I need to keep the NAT acceleration enabled if am using the Asus router AC68U latest firmware 380.61 in AP mode? I have not found any specific articles to AP and NAT acceleration but would assume it can be disabled?
**** Update, I decided to disable the NAT acceleration but I have no option to re-enable it. In fact I can no longer see any of the LAN options as I did for jumbo frames, NAT acceleration or spanning tree. I do notice better performance but the CPU does spike a bit more during speedtest.
2. My Asus displays channel 6 as primary and 8 as the extension. When I use the Acrylic WiFi or inSSider application, both report that am using channel 6 and 10. Why is there a discretion between what the Router reports 6+8 vs. the applications 6+10? Not sure if this is a bug with the firmware?
two questions
