NAT Acceleration prevents Wi-Fi Calling from working
D
Deleted member 58331
Guest
Hello,
You may remember me from when I asked why my ASUS AC3100 was not working with iOS Wi-Fi Calling. I finally figured out that NAT Acceleration is what prevents it from working, but I don't want to disable it because my speeds drop from nearly 1 Gbps to 300 Mbps...
Is there a way of fixing this issue?
When you tried replacing your router with a different model, was the replacement an Asus router with stock firmware and what model was it anyway?
I did not try with a different model but my router was replaced by the same model.
