I need some advice / info, based in UK.
Currently:
-I have a Netgear RAX200 (works and stable for me).
-I have a powerline adapter going from the router to a switch in an adjoining room (all wired connections to devices in the adjoining room).
-I cannot run a cable.
Unfortunately the powerline adapter is quite slow (recently bought and returned a G.hn adapter since it would frequently disconnect).
I am now considering getting the Asus XT9 2 pack (£390 on Amazon atm) and using the UNII-4 band to backhaul to the satellite and use only the LAN ports on the satellite and not broadcast wireless from it. My hope is that I should be able to get at least a 2Gb connection between the 2 units.
My question is; would I be able to achieve what I want by adding an additional unit to RAX200 or must I go the MESH route? £390 is quite expensive for me.
I chose the XT9 because it's triband and has UNII-4 capability and multiple LAN ports.
If I go with mesh, is my choice of the XT9 good or is there better?
Thank you in advance for any advice.
Currently:
