Need help - Can't SSH into router - acces denied
AndrewW
Hi all, thank you for reading.
I have a Asus RT-AC5300 with Asuswrt-Merlin, firmware version 386.3.2
I want to use Diversion add blocker on my router, and i need an ssh connection to it in order to run the scripts
I have JFFS custom scripts and configs enabled.
Under the Administration, system tab, i have SSH enabled .
I have used WINSCP and Putty to set up a SSH connection but i keep getting acces denied when setting up a connection.
I am 100% positive i am using the correct username and password.
Did some googling but cannot find anything specific other then changing the username to ROOT.
I also rebooted my router after enabling the settings just to be sure.
Anyone have any suggestions why i am not able to acces my router using SSH?
