Need help configuring Orbi RBK50 DNS servers
smtelegadis
Want to start off by Thanking @Voxel for the hard work. Definitely extended the range and abilities of my v1 RBK50 and v2 RBS50 hardware.
Can someone point me to a good thread or tutorial that shows how to properly configure the DNS Servers? I'm pretty sure that needs to be done from the dnscrypt-proxy-2.toml file (NOT THE GUI as that doesn't work) but I can't get the settings to bind on the reboot. I used the QuickStart.txt directions set up USB overlay and entware per the instructions running RBK50-V9.2.5.2.38SF-HW.zip for the router and the satellites. Have docker containers using Pi-Hole or Adguard Home (testing both independently) on a Trunas Scale docker container running on IP 192.168.1.39 port 53 but it won't apply on reboot.
Frustrating because of my abilities but I don't want to mess up the routers or my family will hate me.
