My AC86U reboots itself every 3 weeks or so. I am trying to figure out why. The symptoms are:
--public internet stops being accessible,
--LAN is accessible,
--memory is about 95% (returns to 70% after reboot),
--swap is 10MB of 255MB (0 of 255MB after reboot),
--router reboot was triggered this morning when I rebooted my modem instead of router.
The AC86U is running 384.19. I have 2 AC68s running as mesh nodes. Those nodes are currently running 386.1_beta1. I realize the nodes should be running identical firmware as the AC86U. I attempted to fix this problem with beta software and had to back out on the AC86U due to issues. This problem pre-dates the nodes running different firmware from main router.
I am remote logging and cannot find anything obvious in the logs that would suggest the cause for this. It looks like a memory leak to me.
