Need help extending wireless network
Phydeauxman
I have a RT-AC68U router and would like to extend my wireless network out to my shed in the backyard. It is approximately 134 FT from where the router is located to the shed. I have a conduit buried in the ground that runs from the house to the shed that I could pull an Ethernet cable thru but not sure what would be best on the other end to extend my wireless network out there. The reason I am wanting to do this is to be able to put wireless security cameras out there.
All you really need is an access point, but there is lots to think about when doing CCTV cameras.
Run your ethernet to the "wireless AP" and then, you would need to configure the SSID and security key.
Ask away though, and I'll see if I can point you into the right direction.
Thanks for the reply. What would be a good access point to put out there that would work well with the router I have?
