Razor512
While this is not a common upgrade these days, I am currently looking for a good pci-e ethernet card that will offer better gigabit performance.
The current onboard realtek ethernet cards do not offer as good of a gigabit performance as I would like.
The main issue are the way it deals with a single connection not using jumbo frames.
With the default setting of having interrupt moderation enabled, single connection speeds top out at around 104 MB/s (around 840mbit/s)
And disabling interrupt moderation will increase that value to 116MB/s (around 930mbit/s) and pings will go down from around 0.09ms to around 0.086ms, which while better, is not full gigabit speeds. (though all of this is at the cost of around 5% extra CPU usage.
If the number of connections are increased, the overall throughput will increase to around 980-990Mbit/s
What I am hoping to find is an ethernet card that can offer closer, or ideally a full gigabit throughput on a single connection
It is difficult to find benchmarks for ethernet cards, as not many people seem to do them (and when you do find them they are usually results measured with a $150 ethernet card
Does anyone have a recommended ethernet card which was able to offer them a full gigabit of throughput (packet overhead included)? (that is not insanely expensive
Wish small net builder could do an ethernet card roundup as it seems that the advanced settings in the ethernet card's device manager entry can impact performance, along with different drivers (along with different models of gigabit ethernet adapters, eg my realtek ethernet card is faster tham my atheros ethernet card)
