So your suggesting keeping the same ssid across board is better option then having each band have it on. Do you have 86 using Merlin? It will be great to know your settings for bands. Like for 2.4 should I leave it to only 20mhz and auto channel and for 5 should I leave to 20/40/80 and auto channel. Also, is it good to keep wirelss mode to auto or should I force only AC or N? BTW i just ordered me 86 on Amazon and can't wait to play around with it .. thank you
Just do as you feel better, all solutions will work, and some for special purposes even better.
If you want some devices only on 5G or only on 2G, than you need different SSID for 2G and 5G, but you allways can use them on AP-node too, makes it easier as you dont need to connect all devices once with each SSID.
Or you use for these devices guest-SSID, means one main SSID 2G/5G, one guest_2G in 2G guest setting and one guest_5G in 5G guest setting.
So you can have all devices on main SSID which shall work everywhere, or some connecting only to 2G or 5G using explicit guest-ssid.
I have it this way, but only for testing each band on each router/node.
Ususally all devices here are allowed to use main SSID either on 2G or 5G.
And I got a guest_friends for friends with easy password maybe changing every month with same guest SSID 2G and 5G too.
If you have lot of signals around let it in auto mode 20Mhz or test all channels if you get one performing better (faster) then the others.
But keep in mind if not auto, others can change their channel and you are fixed to whatever you set long time ago.
If others are not strong in your area you can set 40Mhz too, would double speed.
TEST it, nobody can say in advance whats will be best for you.
5G let it auto 20/40/80 and autochannel, probably the best for most home users.
And dont forget: clients connected to node even using guest SSIDs will allways be able to reach your intranet on main router !!!
If you dont want this you must disable guest SSIDs on nodes!
Aimesh wont make guest SSIDs too on nodes for same reason, so that wont help you either ...
Till now and maybe never (?) they did not tell anything about this issue or whether they will support guest in future Aimesh.
